11 120 -
44
#BO7 beta Activision twierdzi, że Anticheat w BO7 osiągnął najlepsze wyniki wykrywanie cheatów, a pod koniec testów niemal 99% meczów było wolnych od cheaterów. Mediana czasu wykrycia cheatera wynosiła 3 mecze.
Dlatego nie ma co zwalac na FG czy inne duperele, albo sie umie grac albo sie nie umie, tak jak ktos nie umie grac to 500fps w grze nie sprawi, ze nagle bedzie dobry
https://gamesci.cn/wukong/news/detail?id=235 Performance Integrated AMD FSR4. On compatible hardware, it will be available in the in-game Settings after updating the driver and enabling FSR4 in the driver settings. (PC) Improved Compatible Mode. Now, with Compatible Mode enabled, ray tracing, frame generation, and some super-resolution functions will be temporarily disabled to help players avoid game launch failures caused by driver, hardware, or system abnormalities. (PC) Adjusted the default graphics settings for certain graphics cards to match the various graphical changes in the current game version. (PC) Significantly improved the lighting quality when Global Illumination is set to low, making it closer to the effect when Global Illumination is set to high. (PC) Adjusted Performance Mode back to 60Hz, reducing input latency and achieving higher resolution than before. However, the lighting quality level has been adjusted to enhance performance. The original Performance Mode is still retained and renamed "Performance Mode (Legacy)". (PS5) Improved the game's loading speed. (PS5) Improved the clarity of certain textures. (PS5) Improved CPU and rendering performance in numerous scenarios. Improved memory usage in numerous scenarios. Improved the quality of motion blur to mitigate the aliasing issues that occur when the camera pans.
Hipotetyczne zalozenie, wchodzisz do loby gdzie kazdy ma mniej fps od ciebie i wiekszy przez to lag pomimo wlaczenia u ciebie FG i co wtedy ?? Cala teoria lezy w gruzach , nie mowiac juz o innych czynnikach, ktorych nie bierzesz pod uwage Wiec nie splycaj wszystkiego do FG jakby to bylo byc albo nie byc Gracze konsolowi maja wiekszego laga i jakos nikt o tym nie pisze, ze to takie bee granie w multi na konsoli a tu niekotrzy maja opscyloskop w glowie i czuje 5ms roznicy A co z graczami na pc grajacym w mniejszym fps?? Tez bedziesz pitolil takie farmazony ??
ehe
No moze jak zrobisz stop klatke i zooma to cos wylapiesz Dlatego nie ma co popadac w skrajnosc no bo nie oszukujmy sie dodatkowe 7ms dla casuala w grze to przeciez zadna roznica, nie wiem czy to by nawet jaki PRO odroznil
Ale tu ludzie graja dla przyjemnosci a nie poca sie jak na turnieju, jak ktos ma wysoki fps bazowy to sobie spokojnie moze grac z FG, tez gralem w becie i wielkie halo sie nie stalo Te 10ms jak ci dojdzie to bez przesady
DLSS/FSR nie powoduje zadnego laga poniewaz to nie fejkowe klatki, wiec im wiecej fps z upscalingiem tym input lag nizszy Spoko ale to nie ma nic wspolnego z cronusem
Urzadzenie do ktorego wgrywa sie skrypty na no recoil Pierwotnie uzywany byl np w lidze coda CDL kiedys na obnizenie input laga pada. Ale rozpierdol
W #BF6 AIM assist jest słabszy z cronusen, niż w CoDzie bez cronusa, a także cronus w BF6 jest wykrywany na bieżąco, a w CoDzie do dziś nie jest wykrywany, więc na forach użytkowników cronusów piszą gracze, że wracają do CoDa 😂
Nie nie trudno, w 2042 na 128graczy 9800XD potrafil mi robic bottelneck
#BF6 Dice: "Proszę, przesyłajcie dalej swoje opinie! Po pierwszym weekendzie z BF6 w rękach graczy na pewno pojawiły się różne kwestie — problemy, błędy, rzeczy, które chcielibyście, żeby się zmieniły… a może nawet pochwały? Wszystko się liczy — chcę to wiedzieć! Zespół też nie może się doczekać, żeby pokazać, jak bardzo nam zależy! " https://x.com/tiggr_/status/1977361535249842218?t=EIvSZWgcp1_dS1kZeUOTPg&s=19
#BF6 ⚠️Battlefield 6 zaczął wykrywać i zawieszać użytkowników cronusów 🎮 (tymczasowe bany) ❗ ⚠️Główny twórca skryptów CronusZen potwierdził to❗ Cronusy w CoDzie nie są wykrywane do dziś. https://x.com/subonekd/status/1977511069158699303?t=9tpPC1exDUYiImuHLK2djQ&s=19
Miex 2x, a 3x nie ma roznic w lagu Dopeiro 4x da sie odczuc.
A jak obliczyłeś to 30% ?
Zwiekszono HP
Black Ops ktory slynie z najlepszego zombie i jest wpsiany w niego jako rdzen bo tym tez ta seria glownie zaslynela nie pasuje ci do coda
Bo go nie rozumiesz jak i seri Black Ops
Wielu nie zaczyna po prostu od kampani a nie to że ją omija
