1 425 -
Treść opublikowana przez aureumchaos
emm to ja poczekac na promke i moze tez cos naprawia zeby lepiej dzialalo.
Czytalem gdzies, ze gra przypomina duzy mod do wiedzmina, nawet focusowanie ponoc tak jak bylo w w3 jest. No i jakies obozy sa co trzeba je czyscic jak w AC?
Wlasnie przetestowalem w resonance Installation 1. Download the latest DLSS5 Autopilot release from GitHub. 2. Close the game before running the installer. 3. Start DLSS5 Autopilot. 4. Select your GPU architecture filter, or choose Show Everything. 5. Find and select your game from the detected library. 6. If the game is missing, use Choose Folder and select its installation directory. 7. Confirm that Autopilot has selected the correct game executable. 8. Open the Route menu and select: Neural Upstream – the network before the upscaler, cheaper 9. Leave these settings on their automatic values unless you know they need changing: ReShade loader: Auto nvngx_dlssnr: Auto – match my GPU HDR: Auto 10. Press INSTALL and wait for Autopilot to finish downloading and configuring the required components. 11. Start the game and enable its normal DLSS Super Resolution mode. 12. Press Home to open the ReShade overlay and configure Neural Upstream from its own panel. Neural Upstream runs DLSS 5 Neural Rendering at the game’s lower internal render resolution before DLSS Super Resolution upscales the image. The game’s own DLSS Quality, Balanced or Performance mode therefore still controls the internal resolution. Important Notes Do not combine Neural Upstream with OptiScaler, the regular RenoDX DLSS 5 add-on, or another NGX hook in the same game folder. Choose your resolution and DLSS quality mode before activating Neural Rendering. Changing them while it is running may cause a rebuild, freeze or crash. Borderless fullscreen is recommended. If you use DLSS Frame Generation and experience stuttering, set the Neural Upstream cadence to Quality in its ReShade panel. Do not use ReShade add-ons in online games protected by anti-cheat. To remove it, select the same game in Autopilot and use its uninstall option. MAgia, mam AI slop i smiga ponad 80 FPS, tak mozna zyc Ale wydaje sie mniej efektywny troche mam aureole
No w grze i były fajne momenty. Oceniłem całość i zachowanie developerow. Brak fabuly, rutyna i holocausty były słabe jednak.
Czy Orange nie chce mieć starych klientów?
aureumchaos odpowiedział(a) na ACH temat w Dyskusje na tematy różne
Czas to jedyna rzecz jakiej ciągle mi brakuje i jakiej nie mogę kupić, nabyć... Siadam, mam ochotę to ściągam i tak chce jak najszybciej bo czasem mam tylko te 30 minut. -
Dodatek Sims jak czytałem...
Kyrie Elejson w końcu skończyłem.... Po prawie 90h mogę szczerze powiedzieć, ze gra zasłużyła na solidne 6/10.... To pierwsza gra gdzie ilosc paczy rozwalających mody stała się przytłaczająca. Bez renoDX gar wyglądała na przejaskrawione cudactwo za to z RenoDX noce i dnie wyglądały bardzo dobrze.. Ale ilosc iteracji ze glowa boli przez dodawanie kotków i piesków z każdym paczem... Po co dodać np quick save (ten mod tez niezle w tyle dostał od paczowania). PA jest kompletnie anty moderskie i maja gleboko prace moderow gdzieś.... Sama gra to po prostu niesamowicie zmarnowany potencjał... Mając taki zespół patchownikow i silnik zrobic cos takiego... Nawalili wszystkiego ale jednocześnie nic ciekawego i interesującego... No jak tak można? Po 60 h FOMO ze cos ominie i za każdym razem albo czegoś brakowało albo po prostu było takie samo jak poprzednio. Ilość miejsc o jakich zapomniałem zeby wrocic to glowa mala... Wiec pytanie na jaka cholere napierdzielic tyle wszystkieigop żeby 2% graczy p[sycho fanow w ogole to zobaczyl????? Zmarnowana kasa i czas. Przy 70h zacząłem się nudzić od rutyny.. Typ który wymyślił te holokausty obozów tez nieźle w głowie miał.. Każda animacja po wygranej walce z bossem identyczna - czyli ciachasz pasek do konca i cut scenka ze juz p[rawie przegrywasz no ale wygrywasz i tak to wyglądało z każdym jednym bosem. Sterowanie to najgorszy babol jaki widziałem dotąd w grach... Za każdym razem jak wracałem do tej gry po jerkiejś nawet krótkiej innej to znow trzeba było przypominać sobie jak sie te cholerne rzeczy robiło typu potrójny jump czy tam force palmy sfokusowane, co to ma byc? BLEEEH. Cieszę się, że to już za mną... Kupiłem to skończyłem i oby mniej takich "mesjaszy" gejmingu Na koniec powiem tak:
no ale do mnie nie dochodzi -
Bo czesto odinstalowuje i instaluje na drugi dzien ponownie gry jak wychodza mody ktore chce sprawdzić... Lub naszla mnie ochota zeby ograc jeszze raz a potem sie rozmyslam... Gry teraz maja po 100gb i dlaczego mialbym dlugi oczekac? Jak mialem 0,5 to malo nie umarlem przed monitorem... Teraz mam 1gbps (jak akurat dziala) i juz jest w miare ok. Nawet idizie na raz np z ubi i steam sciagac... Marzyl mi sie 2gbps.... -
perki nie zabieraja i 90 dni i love it Chyba zakupie geiere na promce jakiejs bo za taka cene chyba az tak dobra ni ejest
To jest max co mi oferuja, nie ma szybszego internetu na mojej ulicy w kamienicy. Szkoda bo chcialbym szybszy. Modem fun box 7 niby. No i technologia HFC no ale z G bata nie ukrecisz. -
ale tylko haslo? nie ma dostepu do routera zeby ustawic sobie np inny kanal, inne ustwienia sieci itp? -
Banishers to byla jedna tych gier niespodzianek, trafilem na nia przez przypadek i jak dla nie to lepsza niz nie jedna nawalnica AAA jak AC sh czy inne. Mi is ebardzi podobala i pod wzg grafiki jak i fabuly. Gdyby na steam decku lepiej chodzila to bym ogral jeszcze raz.
Nie mam pojecia, mieszkam tu od 8 lat i zawsze byl UPC a potem pojaiwla sie naklejka orange. Netia i inne nie wchodza. UPC dzialalo bez zajakniecia tyle lat, przyszedl play i wczoraj znow niby internet jest a go nie ma, wlaczam VPN i strony dzialaja, wyl VPN i strony nie dzialaja... wl i wyl router znow zaczyna dzialac i tak w kolko do zaj.... najgorsza usluga ever... a jak z torrentami? plokuja P2P? Mozna samemu skonfigurowac ich router? w sensie kanaly, nazwy, hasla? Na stronie orange po wpisaniu mojej ulicy pisza ze moga mieszany mi dac wlasnie swiatlowo i potem coaxial tylko, max predkosc do 900 (W upc/play mam 1gbps) PS. Play to w ogole niezle ułomy są. Mam caly czasz stara umowe jeszcze ktora bralem z UPC i przesza ona kiedys na bezterminowa... i Dzownia co jakis czas do mnie z play i namawiaja na podpisanie z nimi umowy ktora zawsze jest droższa od tego co place teraz. Pytam sie konsultanta jaki mam interes w podpisaniu umowy z Wami zeby miec to samo za drozej? - odp kon - bedzie Pan w Play tadam -
A podepne sie z pytaniem. A jak dziala u nich ten swiatlowod w orange? Ja mam teraz po UPC czyli play i odkad ma to play to jest tragedia straszna. Ciagle problemy z DNSami i ciagle musze restrtowac router... i widze z e mam w kamienicy tez orange i zaczalem sie zastanawiac czy do niech nie przejsc. Chcialbym 1gbs. Dziala to unich jako tako?
