Nowy patch idzie, człowiek giną a dodają respawny do bossów(ogólnie na plus).
Więcej i lepsze checkpointy na mapach to dobre też.
Spoiler
We're currently working on a 0.1.1c patch for Path of Exile 2 that will include some bug fixes and minor new features. We plan to deploy this patch by the end of this week. Full details will be included in the patch notes, but in the meantime here is some of the changes you can expect to be in it:
Features:
Added up to five respawn attempts for the Twisted Domain area, based on the area difficulty.
Added up to five respawn attempts for the Olroth, Origin of the Fall boss fight, based on the fight difficulty.
Added up to five respawn attempts for the Crux of Nothingness area, based on the area difficulty.
Added Minimap Icons for Strongboxes.
Minimap Icons for League mechanics now remain visible regardless of how far away you travel from them, making it easier to return to them later.
Added more checkpoints to several Map areas and improved the placement of some checkpoints.
Minions can now briefly squeeze through smaller gaps if they've failed to move for a short period.
Bug fixes:
Potential fix for the crash affecting Win 24H2 players.
Fixed a bug that would prevent kills with Damage over Time being assigned correctly to players, most notably any death to poison or bleeding while the monster still had Energy Shield at the time of death.
Fixed a bug where parts of the Atlas could fail to render if they were far away from your most recent map.
Added the "/ResetAtlas" chat command which can only be used to reset your Atlas when it's in a bricked state (no available maps).
Fixed several client and instance crashes.
Gamepad:
Increased font size of text in various locations when using a controller.
Improved item navigation when using a controller.
16 godzin temu, Imm napisał(a):
Poziom podnosisz za pomocą uncut skill/support gemem z wyższym poziomem
Teraz to mnie rozłożyłeś na łopatki, quality support gemów też można podnosić? :wariat:
Edytowane przez wkamil73
  • Haha 1
Oczywiście, Panie. ;)
Większa implikacja z tego jest taka, że w najbliższych tygodniach nie będzie wersji 0.2, bo inaczej by się nie bawili w tego "pośredniego" patcha.
Chciałem do buildu kupić sobie najlepszy polecany łuk na rangera WidowHail - wchodząc na stronkę poe trade wszystkie dostępne do kupna są "corrupted" czyli już nic  z nich nie można zrobić a tymbardziej używać to po co ktoś to jeszcze sprzedaje ?
Nie jest to najlepszy łuk dla Rangera. Jest to najlepszy łuk do początkowego levelowania.
Po drugie, w czym to przeszkadza, że jest już corrupted? Możesz go normalnie używać, bez ulepszania, później i tak zmienisz. Ludzie próbują z korupcją aby dodać slot/statę, bo takie sprzedaje się za więcej. Nie zmienia to faktu - użyteczności tego łuku pod początkowe levelowanie.
Edytowane przez Imm
Myślałem, że coruppted itemków nie można używać.  Chodziło mi o levelowanie, że najlepszy.
Widowhail dobry do poison concoction Pathfindera, bo skaluje +level z quivera. Ale to później, bo quivery +2 są ilvl 32+.
Do levelowania rangera najlepiej byle łuk z +%phys damage i włóż dwie runki na lightning damage i wykosisz cały pierwszy i drugi akt.
Edytowane przez Ozonek
W sumie to ja już dawno po jestem :D Już mam Crueal act1 i po prostu szukam coś lepszego od obecnego łuku który trochę już mam.
Hm... to w takim razie rozejrzyj się za łukiem po DPS. Ustaw sobie na trade filtry "Max required level" i DPS, na 45 level jest sporo łuków 200 DPS+ za 5-10 exów.
Mocno odradzam ten build, single target po nerfach jest słaby i na pinnacle bossach można się spocić(T4), zupełnie bez większego celu. Są lepsze opcje dla Rangera; to tak tylko informacyjnie, żeby ktoś się w niego nie pchał.
Edytowane przez Imm
Jak wszystkie? Zaznaczasz w opcjach że ma nie być corrupted i po problemie. Ludzie szukają np tego z wysokim rollem i 3 socketami a taki może być tylko corrupted. Jak niby tego nie da się używać? Zamiast liczyć na RNG płacą hajs i kupują gotowca.
Zbrojka za 3exy, ze skrzynki corrrupted wypadła fajna czapka - a byłaby zajebista, gdyby nie była corupted - no i mam już ponad 9k ES jeszcze bez tego noda podbiającego ES ze zbroi.
20 minut temu, galakty napisał(a):
+200% do stun buildup to rzeźnia :E :E
Na czym taki stat?
Oj tam zaraz, dzięki takim modyfikator doceniasz staty na drzewku i itemach "+/%stun treshold". :D
Burning ground to też jest szybka śmierć jeśli nie przywiązujesz uwagi. :D
Padłem prawie bo postawiłem portal do miasta na nim i się skapnałem w ostatniej chwili xD Najgorszy modyfikator razem ze stunem jak dla mnie :E
36 minut temu, wrobel_krk napisał(a):
Wiesz są rzeczy pod 100 divine i się sprzedają, kwestia ceny i itemu. Jak dasz dużo taniej niż coś warte to od razu się kupiec znajdzie.
To jak z cenami na używane 4090 przed i po premierze 5090 :D
  • Haha 2
Często sprzedaje itemy po kilkanaście Divów za jeden i nie ma problemu, musisz zwyczajnie wiedzieć, co jest obecnie na topie jeśli chodzi o buildy i czego ludzie szukają.
Jak sobie dowalisz do mapy emocje tak powiedzmy na 50+delirius to wtedy mgła jest na tyle gęsta, że łatwo przeoczyć palącą ziemię i... pyk... nie ma Cię. :D
