10 godzin temu, Hard Reset napisał(a):
Najnowszy CoD 4, odpaliłem z Mochizuki 0.0.7 Model B, na AMDNR 0.3.5.8R10.
1440p, RT, FG, FSR4 Q, z włączonym NR płynność raczej średnia, widać po FPS z FG.
RT + NR, to się nie mogło udać xD Nawet na RTX 5070 Ti nie miałbyś w takich warunkach dobrej płynności.
Ale wiesz co dziwnego zauważyłem ? Że czysta gra bez instalacji AMDNR działa wolniej niż po instalacji moda . W testowym miejscu gra bez moda 98FPS a po instalacji moda ~115FPS %-) bez włączania DLSS5 NR.
Edytowane przez Hard Reset
Nowa wersja moda od Daniela .
Alpha 0.9.0-pre1
New DLSS-SR presets K and J (DLSS 4 transformer). Auto now picks K, M or L per mode, like NVIDIA
New DLSS-NR model CC, 40-80% faster. Requires DLSS-NR 310.9.16 or later
New DLSS-FG preset C (Lite), 100% faster
Added RDNA2 support for DLSS-SR, RR, and FG (I could only test this on an emulated RDNA2 card, report if you find any issues)
Upgraded the bundled FSR to 4.1.1 and FSR-FG to 4.0.1
Added support for driver-upgraded FSR 4.1.2 and FSR-FG 4.0.2
Multiple performance improvements across all networks
Reduced the mod size by 40%
DLSS-FG on AMD mod
Added support for up to x6 MFG, requires a game with Streamline 2.14 or later
Added support for the new DLSS-FG Lite model (preset C), 100% faster than A and B
New DLSS-FG multiplier settings: the game's choice, Fixed x2 to x6 or Dynamic (picks the largest multiplier that fits your display's refresh rate)
4% performance improvement over v0.8.0
Added a new Fast mode (12% faster than Reference)
FSR Frame Generation can now be used with DLSS inputs (x2)
DLSS Frame Generation can now be used with FSR inputs (x2)
Switching the frame generation provider no longer needs a game restart
Added software path for PCs without hardware GPU scheduling (HAGS)
Clearer overlay status: which generator and multiplier are running, what limits them, and whether the frame rate fits your display
DLSS-NR on AMD mod
New CC model, 40-80% faster than HT
5% performance improvement over v0.8.0 in Fast mode
7% performance improvement over v0.8.0 in Reference mode
DLSS-RR on AMD mod
11% performance improvement over v0.8.0
Transparency effects like rain, smoke, lasers and liquids are no longer missing in games that pass them separately (e.g. Cyberpunk)
Much less stutter when the game changes resolution
Fixed a VRAM leak when switching upscalers multiple times
DLSS-SR on AMD mod
12% performance improvement over v0.8.0
Ported models K and J
No more stutter on the first frame, and much less when the resolution changes
NeuralHub
The game page now shows which inputs each game offers (DLSS, FSR, XeSS)
Faster startup
Smaller installer
Fixed crashes on unusual game files
Stability
Fixed device hangs with DLSS-SR / DLSS-RR in RE Engine games (Pragmata, RE9, Dragon’s Dogma 2)
Fixed a crash at start in Star Wars Jedi: Survivor with the GPU spoof
Fixed a crash at start in Forza Horizon 6 (Microsoft Store)
Fixed a crash in Spider-Man 2 with the GPU spoof
Games no longer report the spoofed NVIDIA driver as outdated (Crimson Desert, Spider-Man)
DLSS is now offered in Unreal games that keep their DLSS files in plugin folders (no manual NgxStandIn needed)
Fixed a random crash at game start in games that use XeSS (e.g. Cyberpunk)
Fixed a crash when the system DLL the mod forwards to fails to load
Many small fixes and clearer log messages
If your game supports DLSS-FG, I recommend selecting that in the game settings instead of FSR-FG
Known issues:
The overlay can register double key presses under heavy game loads
NR can be aborted on slow iGPUs
Some DLSS-SR presets don't work at some resolutions
The Reflex to Anti-Lag 2 mapping has been temporarily disabled during FG due to performance issues
Selecting a large DLSS-FG multiplier can cause lag in some games
Cyberpunk forces V-Sync off when DLSS-FG is enabled
Nowa wersja od TheAutomatic , przynosi silnik Mochizuki w wersji 0.0.8.2.
A chyba projekt Mochizuki znikł z githuba, bo nie mogę znaleźć .
v1.14.0 (vs v1.13.4.3)
Major release: Mochizuki 0.0.8.2 official ASI takeover for Neural Rendering, 4-network model lifecycle support, launcher MZ4 share/import code system, and comprehensive UI localization and installer fixes.
Mochizuki 0.0.8.2 Official ASI Takeover & 4 Networks
Official ASI Takeover: Integrated official dlssnr-amd.asi for NR processing. The host Ins menu gracefully redirects to the native NR Control menu toggled via End; FSR Super Resolution, Ray Reconstruction (RR), and Frame Generation (FG) operate seamlessly.
Four-Network Architecture: Full support for small, experimental, original, and int4 models. The launcher automatically derives secondary models with dependency locks ensuring required base models remain selected.
Launcher & MZ4 Style Code System
Single-Line MZ4 Share Code: Export and import settings via compact Base64 codes with schema coverage across multi-layer pipelines, RenoDX / wilsjo2 parameters, and presets.
Diff Preview & Reset Tracking: Import dialog features compact summaries, capped 30-entry side-by-side diff previews, and explicit warnings for default reset values.
Standalone ASI INI Tools: Direct file export and import buttons in the launcher for dlssnr-amd.ini to streamline configuration backups and sharing.
Localization & Setup Refinements
Language Sync & Preference Retention: Overwrite installs follow the launcher language (zh-CN / English); kept installs strictly preserve existing user preferences (including explicit empty English defaults).
Terminology Polish & Prompts: Standardized upscaler terminology; placement options labeled as Before the upscaler (higher FPS), After the upscaler, and Present; adopted industry-standard Pass / Passes; missing model prompts direct to launcher extraction.
Known Issues
Ray Regeneration is experimental and off by default; switching RR/SR modes relies on NGX feature recreation.
Most games need DXGI spoofing to expose DLSS/RR options; some titles may report unsupported GPUs with spoofing active.
Experimental and INT4 models require specific hardware instruction sets (RX 9000 series recommended).
RenoDX cannot be combined with person protection; Linux/Proton support is experimental.
Nowa wersja moda od Wehaveall , ponoć duży przyrost wydajności w porównaniu z innymi modami. Trzeba będzie sprawdzić ;)
https://github.com/Wehaveall/AMDLSS5/releases
AMDLSS5 2.0
The biggest update so far. The mod now runs on its own engine, it is much faster, and three more games are supported.
Performance
New engine: the mod now runs on its own engine, written for this project. It no longer depends on any other mod's files.
Faster: in Resident Evil Requiem (same scene, 60 s, 4K, FSR, RX 9070 XT), 2.0 runs at 101.2 FPS on average (1% low 78.5): +64% FPS and +41% on the 1% low compared with other mods (61.6 FPS, 1% low 55.5), and +11% FPS and +19% on the 1% low compared with 1.6.1 (91.3 FPS, 1% low 66.0).
Fewer small periodic hitches: network results reach the screen faster.
FPS limit in steps of 5, up to 240 FPS.
16 minut temu, jankooo napisał(a):
Nawet fajnie to wygląda ale przy tej ilości zakłóceń obrazu to do grania się nie nadaje. W Robocopie miałem takie flesze ale ostatnio jak sprawdzałem to już git było i obraz stabilny.
Ja za bardzo zakłóceń tam obrazu nie widzę. Pod kapeluszem gościa jedynie mruga jakby cień. Może wystarczy coś tam suwaczkiem poustawiać aby był stabilniejszy obraz. ;)
Testowałem za to Path tracing z modem na regenerację promieni wygląda to już dobrze, tylko wydajność średnia %-). Może wrzucę później jakiś film. Póki co SS.
15 minut temu, RTXnietylko4060tiUSER napisał(a):
@Hard Reset Gdyby to mialo tak maly wplyw na wydajnosc, to byloby super. 50% FPS oddawac za ladniejszych NPC nie zamierzam.
Jak włączę FSR4 quality i FG to jest ponad 200FPS w 1440p %-)
10 godzin temu, jankooo napisał(a):
Pod kapeluszem to co innego, to błąd po stronie jakby nakładających się tekstur.
Na początku na krzakach widać na przykład. Chyba, że te błyski to burza%-)
Teraz zauważyłem te błyski jak napisałeś. Ale widzę że one występują nawet jak mod jest off, zerknij w prawy górny róg , bo co jakiś czas robię on/off .  Podczas nagrywania tego nie zauważyłem . Musze zobaczyć normalnie w grze , bo nie wiem czy to burza , błąd przy nagrywaniu filmu, czy coś z modem ;)
W dniu 9.11.2026 o 23:36, RTXnietylko4060tiUSER napisał(a):
 @Hard ResetWrzuc, chetnie zobacze.
Proszę Cię bardzo , path tracing w 1440p na Radeonie .
Przecież tylko na RTX można PT i to z MFG x4 xD:faki: ;)
Mod jaki użyłem to OpenNR 0.9.6
  • Thanks 1
Odpal PT w Wukongu mądralo :hihot: W Residencie rzeczywiście działa to całkiem nieźle.
Te błyski to jednak nie burza , powoduje je nakładka REFramework i włączenie optymalizacji RT, daje niezłego kopa 20-30% w PT ale obraz co jakiś czas miga . Próbuje rozwiązać problem ;)
No i to jest z Tobą problem w tych porównaniach. Napakujesz wszystkie dostępne tricki, żeby było szybciej, czy to aplikację NR przed skalerem, czy to cięcie jakości RT/PT z moda, i weź tu porównuj z tym :hihot: A jaka jest rzeczywista wydajność 9070 XT z PT vs 5070 Ti przy tej samej jakości obrazu (czyli w obu przypadkach z DLSS RR) możesz zobaczyć w moim nowym teście:
https://ithardware.pl/testyirecenzje/dlss_rr_na_radeonach_test_opinia-55631.html
Tutaj oba GPU działały bez żadnych tricków i optymalizacji, które tną jakość :)
Fajnie że udało Ci się dorwać 9070XT do testów :).
Na tym moim filmie wyżej nie włączałem tej optymizacji i obraz nie miga ;)
Oficjalnie przecież PT nie da się włączyć w RE więc używam różnych sztuczek . Póki co chyba OpenNR z OpenRR jest najlepszy, gdyż wychodzą często nowe wersji w porównaniu z modem Daniela.
Moda daniela nie mogę sprawdzić w RE bo mi wywala grę z AMDNR, na czystym NeuralHub nie sprawdzałem.
Ta optymalizacja RT w REFramework daje dużego kopa, o gorszej jakości się nie wypowiem bo za mało jeszcze grałem przez to miganie , ale prawdopodobnie już znalazłem rozwiązanie. Moze nagram film porównawczy. Póki co mogę tylko napisać że np wyłączenie DLSS FG x2 i włączenie AFMF2.1 daje około 15% więcej FPS. Natywnie 60FPS, z DLSS FG 97FPS a z AFMF 115FPS , więc różnica jest . Jakość podobna.
Tylko wiesz, nawet jak rozwiążesz problemy, to przecież można te same optymalizacje zrobić na RTX. Różnica wydajności zostaje.
No tak , ale po włączaniu tej optymizacji wydajności, wydajność w PT jest taka jak gołym RTX5070Ti. Przynajmniej tak mi się wydaje oglądając filmy na yt z RE PT na RTX5070Ti.
Nie chodzi mi o to żeby udowodnić że RX jest tak samo wydajny w PT, bo nie jest i nie będzie, ale bardziej o to aby ludzie bzdur nie gadali że jak PT to tylko RTX. Sam widziałeś że powtarzają bzdury z czasów rx7xxx gdzie dużo więc radeony odstawały w RT nie wspominając o PT. I będę to powtarzał jak ty to nazwałeś jak zdarta płyta, do póki ktoś będzie takie kocopoły gadał ;)
W dniu 13.11.2026 o 20:44, RTXnietylko4060tiUSER napisał(a):
Nastepna generacja pozwoli na sensowna zabawe z PT u czerownych.
Aż się boję, ile ta "zabawa" będzie kosztować, bo jak będzie to działać dobrze, to tanio nie będzie. Nie bronie im - niech sobie zarobią, ale coś czuję, że próg cenowy będzie ustawiony stosownie do progu NV, czyli będzie gorzej, jak teraz.
