33 minuty temu, Brolly napisał(a):
Ja nadal nie wiem co ludzie chcą od tych czcionek, u kumpla na 1440p 27" nie widzę specjalnej różnicy vs ips.
Jeden widzi różnicę, drugi nie. Na pewno jest coś na rzeczy, bo Rtings ocenia to niżej niż np ips, czy 4k 32 cale OLEDY,  ja np widziałem różnice jak np kolory nie do końca prawidłowe, przy np edytorze kodu gdzie masz różne kolory to widać, zwłaszcza jak przed chwilą patrzyłeś na IPS.
Subiektywnie czyli poza oceną punktową, testerzy z Rtings też oceniali, jednym przeszkadza bardziej lub mniej, lub wcale, np:
Cytat
1. Clarity: Honestly, the text clarity is ok. You can tell that it’s not perfect, there’s some minor color artifacts around certain letters and different colored text sometimes ends up looking a little funky, but it’s only a little worse than other 1440p monitors I’ve used. If you’re on mac though it’s definitely more annoying. I found the text noticeably not that sharp on macOS, especially if you have your Macbook right next to it.
2. As for text clarity, I struggled to get over it. In an office setting, like reading through a document, it’s just not clear enough for me to read without feeling strained after too long. Writing and reading comments definitely felt more straining on my eyes, not necessarily uncomfortable, but just not as good as it could be. I used the Better ClearType Tuner that another user mentioned which remedied this for me.
3. This wasn’t an issue for me at all. I used Better ClearType Tuner, adjusting the contrast to between 1800-2200 and I didn’t notice any fringing at all or other text issues. I used Windows’ default scaling, and text was crystal clear and sharp. I actually found it easier to read than the S3422DWG I normally use, probably due to the screen coating. If I really tried to look for color fringing I could still see it in some spots, but overall it just wasn’t an issue.
https://www.rtings.com/discussions/VVRExc2bCpDGLxs9/beyond-the-measurements-our-own-subjective-impressions
Jeśli postawisz obok siebie różne matryce, to zobaczysz. QD jest jakby trochę mniej ostre, woled bardziej postrzępione, IPS wygląda ciut ładniej, ale to jak porównujesz podobne PPI. Jeśli obok 27" oleda postawisz IPS taki biurowy standardzik 24" 1080p, to wcale nie będzie wyglądał lepiej. A przez wiele lat w pracy i na studiach używałem jeszcze gorszych rozdzielczości/ppi...
Właściwie to przeważająca większość oprogramowania, którego używamy na co dzień została napisana na gorszych ekranach niż tu dyskutowane. Jakoś się dało ;)
7 godzin temu, Kadajo napisał(a):
Ludzie się naoglądają YT, potem biorą lupę no i masz.
Sorry ale OLED na 27" ma kiepskie czcionki i każdy to widzi. Tylko nie ktoś kto ma 1080p bo dla niego to będzie żyleta xD
Po 2-3 dniach nie robi to już wrażenia, ale różnica jest. I do tego fringing.
Edytowane przez galakty
Jeśli po 2-3 dniach już to nie robi wrażenia to jakie to ma znaczenie ? Żadne.
Rozumiem ze jeszcze ktoś miałby dwa monitory obok siebie i faktycznie mogłoby mu przeszkadzać, że na jednym czcionka wygląda lepiej. Ale nie przy jednym monitorze.
Wystarczy poświęcić trochę czasu i ustawić sobie CC tak jak komuś tam pasuje, to nie zostało dodane do systemu dla beki.
Ciekawy jestem jak wiele osób nawet by nie zauważyło tych problemow gdyby nikt o nich nie pisał czy pokazywał pod lupą na YT.
  • Haha 1
Jest różnica między IPS i OLED. Widać ją gołym okiem. Ale idzie się przyzwyczaić.
Edytowane przez Passt
Właśnie mam dwa obok siebie? xD
Czcionka jest słaba na OLED 1440p i to widać od razu, a że się człowiek przyzwyczaja to tylko zasługa naszego mózgu i adaptacji. Nie trzeba żadnych magicznych testów czy YT by to widzieć, a jak ktoś nie widzi to powinien się udać do okulisty.
Ten "problem" jest 100x bardziej widoczny niż wypalenia na OLED, do którego trzeba właśnie testów na YT i specjalnego rozjaśniania zdjęcia bo inaczej nie widać.
1 godzinę temu, Gret napisał(a):
@Umpero jak robisz u sobie kalibrację HDR apką z win11 to jakie Ci wartości pokazuje? u mnie to 400/500nitów max. Na G7 mam 1000nitów.
Kalibrację robiłem apką od win11.
Natomiast konfiguracja według poradnika z linku.
Najpierw konfigurujesz dla trybu SDR gdzie nie będziesz miał 1000 nitów, a później dla trybu HDR.
Żeby osiągnąć 1000 nitów musisz mieć ustawioną szczytową jasność na "Wysoka".
Tutaj w tym poradniku robią dodatkowe profile dla SDR I HDR. Nie musisz tego robić gdyż monitor sam zapamiętuje ustawienia dla tych dwóch trybów.
Wystarczy, że w Windowsie będziesz przełączał i monitor sam zmieni dla tych trybów ustawienia.
Jak już poustawiasz to w trybie HDR odpalasz kalibrację.
Edytowane przez Umpero
@Gret dziwne. Wgraj jeszcze sterowniki od monitora jak tego nie robiłeś.
Podłączone masz jakim kablem? Mój egzemplarz jest bardzo wybredny.
Tylko na oryginalnym kablu HDMI z zestawu tego monitora działał bez migania.
I to też pod warunkiem jeśli nie był blisko innych kabli.
Dopiero jak kupiłem optyczny HDMI 2.1 to zniknęły wszystkie problemy.
Ja bym na Twoim miejscu wgrał sterowniki, zresetował do fabrycznych ustawień i ustawił od nowa wszystkie opcje.
Podłączony mam na DP z kartonu od monitora. Sterowników nie wgrywałem, zaraz ściągnę. A Ty jaką masz wersję oprogramowania bo coś mi się wydaje że poprzednio miałem 1400 i tam jak robiłem kalibrację to były okolice 1000nit, jakoś niedawno mi samoczynnie wskoczyła 1301.
4 godziny temu, Godlike napisał(a):
Jak ogladacie jakies filmy/seriale w stremingu np. które używaja HDR, to włączacie tego Windowskiego HDR?
Generalnie jeśli chce się skorzystać z HDR czy to w grach czy filmach lub streamingu należy włączyć HDR z poziomu Windows aby prawidłowo to funkcjonowało.
Ja od paru dni jestem posiadaczem LG 27GS95QE (zależało mi na matowym ekranie bez kropek kwantowych m.in. z racji lokalizacji biurka obok okna orzrz które przez większą część dnia pada światło (oczywiście jak jest go za duzo to przysłaniam sobie roletę, ale nie robię pełnego zaciemnienia :) ).
Generalnie jestem zadowolony, ale zastanawia mnie czy lekki  (zarówno przy SDR jak i HDR) w grach, czy podczas odtwarzania na YouTube w SDR jest normalny? Przy filmikach testowych HDR z YouTube wszystko jest OK, ale przy treściach SDR z Youtube, czy w grach (widoczny ciemnych miejscach czy na przejsciach cień-światło) zauważam u siebie taki efekt, którego nie widziałem na poprzednim monitorze IPS (ale może że względu na niski kontrast w porównaniu do OLED?).
Widać to np. w Indiana Jones and Great Circle w sytuacji gdy postać kleczy i robi się winieta na rogach ekranu - w ogóle w tym momencie ta winieta łapie taki jakby zaniebieszczony odcień i nie wiem czy to normalne, bo generalnie jakość czerni jest idealna jak przystało na OLED-a. Poniżej wrzucam zdjęcie zrobione telefonem jak to wygląda (mniej więcej tak to wygląda, zdjęcie generalnie zrobione celowo z krótkim czasem naświetlania, bo inaczej na zdjęciu te zaznaczone rogi "swiecily" mocno na niebiesko, a w rzeczywistości efekt jest słabszy, mniej więcej jak na tym zdjęciu. Czy u was ta winieta przy kucaniu też tak wygląda? I czy ten color banding jest normalny? Tak jak wspominałem wyżej nie występuje on zawsze, więc raczej nie jest to wada matrycy, ale może się mylę?
U mnie w testach pg39wcmd
39" vs 34" robi robote
Rozdzielczosc ta sama wiec czcionki naturalnie gorsze
Jednak siedzac 75-78cm od ekranu (pg ma 800r) immersja o wiele lepsza.
Moze ktos jest zainteresowany moim g8 34"?
Bardzo malo uzywany, stan oceniam na ideal :)
10 minut temu, Godlike napisał(a):
No ja włączyłem na chwilę Windows hdr przy 3 odcinku 7 sezonu gry o tron i jakoś dziwnie to wyglądało, za jasno, jaskrawo.
Ale całość obrazu była jasna? Czy tylko poszczególne sceny?
Poniżej wrzucam jeszcze zbliżenie na jeden z narożników na którym lepiej widać o co dokładnie chodzi w moim przypadku. Nie wiem, czy to normalne na OLED? Monitor podłączony przez kabel DisplayPort 1.4 (zamówiłem już HDMI 2.1 i czekam na dostawę i zobaczymy czy to coś zmieni), w panelu nvidia ustawione oczywiście na RGB, pełny zakres i 10 bit
Hmm, to może być też kwestia Win 10, bo 11 mam poprawione wsparcie dla HDR. Nie wiem czy na W10 można skalibrować HDR aplikacją od Microsoftu, ale możesz sprawdzić. W sklepie Microsoft musiałbyś wyszukać apkę o nazwie "Kalibracja formatu HDR systemu Windows", przeprowadzić prostą kalibrację która ustala minimalną i maksymalną jasność ekranu i potem dla trybu HDR trzeba ustawić utworzony w apce profil. Tylko właśnie nie wiem czy W10 to wspiera
EDIT: Już znalazłem, niestety ta kalibracja wymaga Win 11
Edytowane przez JohnyWol
